Originally Posted by
jko2
Not quite right here, you gain power with a light flywheel, it is very minimal, and probably won't feel it, but it is still there.
A light flywheel will allow more power to be transferred to the wheels/ground as it needs less power to rotate its own weight.
power upgrades in s2ks are a joke, an aftermarket engine management is ideal for the early model s2ks 99-01 as they run quite rich factory. 02+ typically dyno 5-10kw higher due to a leaner more agressive mapping.
Short of doing forced induction, there isn't much more we can do.
oh wait, light wheels make a big difference. Our stock 16" are pretty heavy even though considered light for OEM. With tyres, they weigh about 18kg.
If you buy larger wheels, make sure you get the right profile. A even slight higher rolling diameter will effectively be meaning your driving with a lower (numerically) final drive.
I made a mistake of putting 235/45/17 on my lightweight 17" wheels - shit branded tyre too BF Goodrich - which actually ahve a bigger rolling diametre than other branded 235/45/17.
