Repco, autobarn, supercheapauto. Get the one for exterior, not interior windows.
Just bought some RainX.Do you have to reapply it every time you wash your car?How long does it last between applications?
It should last 2-3 months, depending on how clean your windscreen is when you apply, as well as how much you use your wipers and windscreen washer. Do you use windscreen washer additive? If you need to use your wipers, it might skip across, so spray some windscreen washer to lube it. But ideally you won't need to use your wipers after applying RainX.
is Sonax safe on paint? looking for new washer additive and seeing how i have a luxury euro the HID washer sprays the headlights and gets all over the paint around the headlights.
cheers aaron.
Aaronng where do you get the piaa wipers from and also where can I purchase pollen filter from besides honda.
I got my PIAA wipers from overseas as I couldn't find them here locally. You could try a shop that sells JDM bling like air fresheners and stuff. They should be able to order it in for your. I paid the equivalent of AU$36 for mine and brought them over with me when I came back from overseas. You need size "82" and size "5" silicone refills.
As for pollen filter, I just use the ones from cabinfilter.net or from ebay. You can also PM destrukshn to get the OEM Honda pollen filters.
