very very true on this front :thumbsup:
but Electronic corrosion control then. done.
What you do is scrape the paint off from around the chassis bolt hole, then bolt down the ground cable's ring terminal so the terminal touches the chassis, then paint over the Bolt and Terminal so air/humidity cannot reach the exposed metal and cause rust. If the bolt goes straight through the chassis, you may need to paint the other side so air cant find its way in.
