Do you drive around with VSA off permanently? What's it like? Any different?
well, no difference if you drive carefully, if you start flicking the steering wheel at 50km/hr + than the car is harder to control
well EBD is designed so that when you apply the brakes, the amount of brake force is electronically distributed to each wheels maximising the effctiveness.
its just due to how the car loads up and unloads underbraking conditions. the advantage is you get more balance out of the car underbraking......i dont see any disadvantage at this stage... maybe just dirtier rear wheels i guess...
well brake dust do come from brake pads when they are used through out it lifetime.
the more wear on the brake pads leads to more brake dust you get.
although the Euro's front wheel is dirtier then the rear.(opposite to the FN2)
im pretty sure that the rear pads gets replaced more often then the front ones by experience.
