same 4 EK's. 14mm bar wont fit with asr, 22,23mm etc will fit.
ystrday i went to a workshop n i saw the guy was fittin ITR sway bar into EM1.. he said it will fit nicely.. i drive EH, n he said tat ITR sway bar will fit EM, EK, EG, EH all nicely.. BUT u have to use ASR brace or other brace to keep the subframe in 1 piece, like EG5 said.. :thumbsup:
n frm wat i know, cusco also make sway bars, rite?? blue will look good :D
I had ITR sway bar on my eg which also had the ITR LCAs..
Connects up to the LCA no prob, but you need to mod the bracket where the bar is bolted onto chasis..
noob question:
how much does a sway bar help? im just about to get a new koni set and wondering if i should get a few extra parts to improve with it if its cheap of coarse. theres is no plans to increase power (gli civic >.> what can do?).
couldnt find any detailed guides to suspension and all.
no it doesnt.
sorry hijacking a bit.
ive been recommended whiteline for swaybars. and in perth wilkinson suspension supplies them, can i just get a whole kit as in swaybar and struts?
whiteline 20-22mm swaybar (EG) + eg6/dc2r lca = no go, they fit but because the lca's are fatter they rub on the swaybar only so slightly
(lowered car,makes a nice clunking noise:) ). its do-able but you need to modify slightly to stop it rubbing/touching
