aaah my bad... the ones i meant aren't by Energy Suspension... their by "Prothane"
you can get em anywhere in USA for cheap.... heres an example:
http://www.prostreetonline.com/x/pro...nt-inserts.asp
you won't be using more than the half litre... the sikaflex tube i bought i'm pretty sure is only 400g and was just right to do all of my mounts except the water filled one which i couldn't remove.
my only other suggestion is to use sikaflex 227 on the front torque mounts and rear as it is soft like the oem rubber... it will still feel solid when fully filled, it will just have a slight flex which will reduce the notorious after-install cabin noise.
Yes energy suspension do make the upper ones. I've got them ordered for my car. Can't rem the p/n though
Awesome! Thanks dsp26!!!!
Found em' on ebay.co much cheaper here.Now just gotta get the seller to send em' to Aussieland :)
cool...man :)
There is a place up here in QLD that restores old mounts with a selection of either rubber or poly in different durometers. I think the place is in Rocklea... I'll see if I can dig up where it is and post the details.
P.S energy suspension make the upper ones also. I brought them with the lower kit. They are a seperate kit for the EK. Had to get them from the US
These are the ones I'm gettin'
http://cgi.ebay.com/ebaymotors/Proth...2em118Q2el1247
Beeza,
get the black ones.
Supposedly the graphite helps (IMHO not), but attract less attention if somebody wants to issue expensive bits of paper.
These days, it tends to be illegal unless somebody has proved otherwise.
Nick.
Thanks Nick,Point taken mate.
