yeah give it a go, cheap alternative but it's been working for the last few days without a problem so far
if you need the ASR inserts just contact them directly in the US. its about 20-25 bucks for them posted to AUS (however you need a paypal account). otherwise you can try and find EK9 bushes and that should do the trick for a DC2R rear sway with ek endlinks.
edit; just ordered them :) $25US shipped
just sent an email through to charleston and he emailed the next day
awesome, you'll be happy with those, makes the ride a little stiffer though, make sure you tighten you nuts properly and re tighten them after 100kms or so or the nut might fall off and you'll lose the inserts. it happens... to me in particular and caused me all sorts.
pretty stiff at the moment with my ghetto bushings but will be interesting to see whether the inserts will help much more :)
I'm in the same situation...
bought a dc2r swaybar and was told ek4 endlinks would work! grr
can you put up a diy?
i'm not quite udnerstanding your explanation
Ta
read the first post dude :)
told you the exact price and part to buy from bunnings, its pretty simple to put 2 and 2 together after that
http://img81.imageshack.us/img81/1609/asrinsertsbv1.jpg
inserts yo :) took about a week to get them
this thread should be stickied up lol. you don't need it for CTR sway bar tho right?
yep you can go ghetto method or get the asr inserts if your kit doesn't come with it
ek9 swaybar ends are different no need for the inserts, only for the teg ones
