Quote:
driving it around 2500 is probably killing your fuel consumption, change gear around 4000-4500 will give you close to optimum fuel consumption (city drive that is)...
Ive found the path to less fuel consumption is driving smooothly and keeping your throttle closed as much as possible. Changing at 4000-4500 is unnecessary particulary in a 2ltr i have a 1.8 and its easily 'torquey' enough to change at 3500 or before. What leads to higher fuel consumption is throttle position and engine speed. If the throttle body isnt open then no air goes past thus resulting in your ECU delivering less fuel into the combustion chamber.
