i have a standard si gearbox. w/ 4.25 FD
can anyone here help?
Is this one you're after?
http://cgi.ebay.com/ebaymotors/OBX-H...7749QQtcZphoto
Im using an OBX LSD in my B20VTEC and Im very happy with it so far, been trashing the shit out of it and been doing its job well
As I've mentioned to you before the OBX LSD for the D series will ONLY fit the SOHC gearboxes. If your gearbox is of that type then, yes, it will fit. Otherwise, no.
is for SOHC, so i doubt it would be compatible
Hey,
If you can, pull both axles out and look through the transmission.
If you can see a shaft across the hole left by the axles, that's normal.
If you can't see the pinion shaft, you got lucky with an OEM LSD.
> I thought all dseries were interchangable.
Not quite.
There's boxes with 35mm axle bearings and 40mm axle bearings. these are somewhat interchangeable. axles are compatible. input splines change 20 or 21 with different clutches for each. cable and hydro shift mechanisms are in-compatible.
There's also the "ZC" d-series which uses B-series sized axles and an intermediate shaft.
> gearbox uses the halfshaft too.
Sounds like a ZC box to me. In which case
Try http://www.quaife.co.uk/Differentials
That's who OBX copied. They have detailed technical drawings with all their LSD's.
I don't think there's any love for the ZC, but you might find something close.
If anybody is interested in special 40mm ID 72mm bearings to fit the OBX into 35mm axle bearing boxes, I might have a lead.
Nick.
i was just told that i just have to use the stock unequal length axles from 92-95 civics and the obx lsd for sohc d series will fit? has anyone with a zc in a eg done this mod before?
