didnt u get ur engine reco? i got my head reco on a 100 000km block so 180-190psi'ish isnt too bad for me =)
Its a bit more of a job then just taking your head off.
different comp tester. Time for new head gasket.
90psi in one cylinder is not good. Time to change headgasket.
cheers for all ur help guys, umm lukenzen i dnt think i'd wanna put new rings in, if u've done it urself its not really fun while the blocks stuck in the car.
i mean while i had the block out in the open one time i could have but i'd probably tipped her upside down and done it but i'd prob jus replace the headgasket. 200psi is good stuff man, i think thats the best it can get for a Y1, she must go good.
Yeah I don't do motor work myself but I can imagine it might be a biatch lol
Won't 180ish to 200ish make a big diff in power in the end result?
I was not aware that 200 was anything special... blocks only done just over 100,000k plus less the 10,000 since new ring install so i guess that helps
Do a dry ANDwet test.That will give you a true indication of ring condition...and also tell you where the compression loss in no.4 is.
hey guys, just wondering if headgasket cracked, how much will it cost to replace?
$100 yourself, $500+ someone else doing it
