how about a t3, t25 or t28? those seem better sized?
T25 for instant boost out of a corner. Good sized for your goals (8psi).
T3, my pick. RB25DET turbos if limited to less than 12psi are sweet. 3-4k rpm boost.
T28 is somewhere in between and a very, very good choice. T28 with A/r = 0.8 from Pulsar GTiR is almost the size of a T3. A/r = 0.63 (eg Nissan 200sx) a bit smaller. A/r = 0.48 at the small end of T28 turbos, comparable to a healthy T25.
There are some boost calculators on the web. Do some research into sizing turbos if you really want to get into it.
Important specs are compressor trim and turbine A/r. A book by Corky Bell is available as a download on the web and is good intro into turbos.
Nick.
Don't forget that the cars you are quoting are 2.0l engines.
The D series does not have that kind of puff. Its only a baby 1.6 SOHC
a T25 should be ok, but a T28 will make abit more power.
Ask Ricer he had a GT28r on his Y8 motor.(and i'm still pissed you didn't let me drive it! I hope your enjoying those rims!)
The rocket kit retails around $3500, call them up as prices change often
nope got a site so i can have a look?
Edelbrock also do a full kit. Individual parts are available if you dig for part numbers.
Fullrace do ram manifolds.
There's a suprising number of turbo piece manufacturers for the D16.
Avoid the Ebay SSautochrome bits. Known to fail regularly.
Nick
having no luck with the greddy kit. anyone know of an australian importer??
edelbrock is wow expensive as is the rocket industries..
PM the guy I got mine off..
http://motors.search.ebay.com/_W0QQsassZracingimporter
