Stut bars = helps keep the casis rigid. thus helping the suspension to move further giving the car a little more handling. stuts also take away vibrations that come from the suspension. thicker the strut the better it is at its job but they alone wont make a drastic difference.
Shocks + Springs = give your car handlin and keeps the car comfortable while going over bumbs.
depending on your driving and how you like your handling setup you should take into account what needs to be changed. stock springs keep the ride height really heigh which in turn gives ALOT of body roll. for instance if you change your springs to low King springs body roll is less. combined with a strut bar handling improves. now if you change your shocks to coilovers you get a better range of handling and comfort. combine that with struts and your handling is greatly improved. coilovers allow user to adjust damper (shock stiffness) settings to driving style. piece of advice when getting struts, always get the front and rear done at the same time.
hope that helps. :wave:
:honda:
