Which release plate and clutch did you get?
http://www.competitionclutch.com/ind...ocation=clutch
Stage 4 Kit - including flywheel, pressure plate, friction disc, release bearing, pilot bearing and alignment tool.
It is double sprung, so there should be a very small window for the friction point... All the best, hope that you solve the problem in the end.
yeah i'm sure it will be ok. I'm not too concerned about the window of engagement. more so that its soo close to the floor which i'm not used to.
If i can adjust the pedal a little bit then great. if i can't then i'll just have to adjust myself instead.
