don't those aftermarket tacho's have a switch for 4cyl, 6cyl and 8cyl? sounds like its on the wrong setting mate
if the cxi's gear ratios are anything like the b16a's, then at 75 in second you'd be in excess of 5000rpm
i just installed an apexi rsm on my cxi. plus it gives you speed, revs and voltage just something to consider instead of just a tacho
How about a Apexi safc? Also has tacho and tunes your air and fuel mixtures for better engine response?
about 95 in second is rev limiter. hit 90 a couple times and listen to the engine. that will be your shift point ;)
60 in 2nd is about 4000rpm which is when my Y4 seems to start making power
Go buy a GLi cluster and swap it in. It'll look better than an aftermarket tacho. It's pretty much just plug and play. There's a DIY in the DIY section explaining how to keep your speedo so you keep your odometer reading too. It's quite straight forward.
