Dude you don't need a mechanic to adjust the damper setting...
Can't you follow aaronng's simple instruction?
Mechanics don't know the differences between coilovers. So I bet you he will turn it all the way anti-clockwise as he thinks that is the softest setting and you will drive around and damage the coilovers.
You don't trust yourself to turn a knob 15 clicks anti-clockwise?
would this be the same for a set of HA's
no manual aaronng, does anyone know?
Yeah I have a manual I will read into that and attempt it. I just don't know what I am dealing with... Like where are the "clicks" now. If I turn 15 clicks I maybe on 10 already thus damaging the coilovers.
I'll look at the manual... It's just that the guy who I bought it off couldn't stress enough "Not to touch the suspension" let a pro do it.
As I said, turn it fully clockwise til you can't turn it anymore. That is the stiffest setting. You can then turn up to 15 clicks anti-clockwise to go softer. Always go full clockwise first before turning it anti-clockwise if you want to be sure you are at a safe setting.
Well tested it and the front suspension was at the softest testing. I guess this is just to hard for me. Maybe need to go back to standard.
I have the standard suspension if your looking to swap
Yeah sorry man I have the standard suspension as well. I was just thinking these are height adjustable as well aren't they?
Does that tend to make the ride a little less bumpier?
