ooooohhhhhhhhh ok, well OP made it sound like the guy was syphoning the oil out through the filler!!!!
Dip stick is possible, but yeh you wont get as much out as you will by draining the sump...
Weeeeiirrrddddd... I wanna know what this garage is now!
Thanks for that lesson in Business studies!
But wouldn't it take longer to syphon it out.. seriously? when you think about pressure etc, would it like build up?
what I mean is, like when you don't take off the oil cap when draining from the sump plug, it takes longer than when you do take off the oil cap. Did that make any sense.. just a thought I had.
I thought that the flow rate out of the sump drain hole was quicker than through a measly tube that fits in the dip stick hole. The only way I can see this benefitting the mech is that he removes only part of the oil (say 3L), so that it takes less time (doesn't have to wait for every last drop to come out before putting the bolt back on), uses only 3L of his oil and saves him 20 cents on that sump plug washer.
But he lifted the car anyway to swap the filter...
Slide over the oilcatcher stand,undo bolt,drain while doing the filter.Simple
This suction idea sounds pointless honestly.
i would back this opinion... :thumbsup:
if you look at it from a process efficiency perspective (where volume of work is your coefficient for increasing bottom line profit) if you had a brain you would do it all whilst your under the car and stop doubling up your time working from the top and then the bottom.... only a dumb shit would do it the other way if they were thinking about time spent and profit per job...
Wow my mechanic sucked the oil through the oil filler cap last time as well! And then proceeded to hoist the car, change the oil filter and rotate the wheels... wonder if it's the same guy lol.
Might be time to practice changing my own oil :P
can u pm me the where this was done?
just curious
Its THE place for "Hondas" in Sydney.
Its lazy , but its to speed up the process and maximize profits DUH. It is a business afterall....
