Not really, all in all about 4 bolts ? Can't remember.
sorry to drag this thread back up but it was the best one i found post-search
the actual loom/plug that needs to come out as the first step, does that need to be twisted to get it out? or just pull straight out... i had a look at my mrs' brothers eg sedan the power steering reservior is right behind it and i didnt want to put too much force without knowing 100% what needed to be done...
just pull out, also pull the p/s reservoir up and that should give you a bit more room to stick your hand in there
if you are having trouble with the light bulb clip you can
use a screw driver to take out the clip that holds the light bulb in
it is only held in by the screw
after you take the screw out the other side should just come out
make sure not to lose the little screw
bulb should come straight out
