Hose n funnel isnt a prob, got that stuff at home. One more thing i just realised tho, u mentioned the crush washers... do i just replace the worn out ones from under the bolts n how much u rekon they'd set me back?
Yes, replace the ones that are on the bolts. They should cost 50 cents each or even less, but the dealer charges a lot more, about $2-3 each! You can get any aluminium crush washer as long as they are the correct size. I will measure the ones I use when I get home. They should be the same size for your car too.
i just called up the honda dealer n the washers r 20mm and 14mm in diameter n they said they'll hook me up 4 free so its all good. Cheers 4 ur help bud, much appreciated! :)
Not a problem. Good luck. Also, when you fill up the gearbox, the car MUST be level. So put all 4 corners on jackstands at the same height.
Yep, will do!
or...do as i do and drop the car back down with a small container BELOW the fill point. Car is flat , as the tranny fills the excess will spill into the container. Let the tranny fluid drip until no more , this is the EXACT amount you need to fill the transmission :)
