install by JB cost $150 as a basic fee for bolt on man.....
i can send u my speakers diagram =)
Looking good Chris........good to see someone taking the time to take photos and do a write up!
Yep, there are probably a multitude of methods for securing it, and I considered the nuts and bolt and washer method.Quote:
Originally Posted by dc
but I thought that the MDF blocks would be simpler and more secure, plus less likely to scratch the door itself (which might cause rust at a later date)
Wat is the most suitable size speakers to fit in a Jazz?
6 inch.Quote:
Originally Posted by Civic Si
cool thanks!:)
no
i find a way you can screw the speakers straight in with smaller speakers
For the correct door trim removal instructions, try the following link. http://www.hondafitjazz.com/manual.htm
This also tells you the entire maintenance schedule and instructions.
Trust the Poms eh boys ?
Hello,
I have removed the door handle cover and the 4 screws.
How to remove the door release handle and the door trim? Are there any tools required?
push to door handle towards the front of the car and pull outwards, there should be a clip holding the latch with a extender bar to open the door, flick the latch out with a flat tipped screw driver and flick the rod upwards - remove the door handle. Remove the door panel from the bottom, there should be a opening about the middle of the bottom of the door trim, insert a flat bar or long flat tipped screw driver and pry it out slowy. if u got small enough fingers - just use that at least u get a feel of what u are doing. hope this helps
Hi Guys
if your intersted I think Stinger Australia does a radio replacement dash kit so you can put in a double or single DIN head unit - if you want to take your up grade further.
