guys all EG civics are hydraulic clutched.
Its a gl as said -
Its a gl as said -
there are no audm ef civics. ef civics are jdm only. audm civics were ed. only local ef are the crx i believe.
and that motor is a d15b4 twin carb, same one as found in ed civics. its not bad in an ed, my mild tune ed makes 80+fwkw with the factory carbs, but it doesnt make enough torque for the heavier eg.
and theres nothing wrong with sticking a pod on the end. you guys do realise that he's probably removed the carby filter, dont you? short rams work well with carbs. hot air further improves the already strong atomisation rate of a carburetor, so it can increase power.
:thumbsup:
2 filters are overkill...
the owner of that car is better off cutting the lid, or replacing it with a non-stick metal sheet that matches the shape of the stock filter to replace the lid to allow the carbs to breathe 360 degrees rather than that one inlet...
i've got a pic on my home computer...i'll post later tonight
