Depends on the tyre shop too. Some like to put 2.0mm toe in eventhough stock specs on the Euro is 0mm toe in. I've seen another put 4.0mm toe in on a Mazda which is nowhere near stock! So unless you have the printout, then it is not easy to diagnose.
If you have uneven tyre wear after Wakie, make sure you rotate your tyres. If yours are directional, then swap them front to back.
