Originally Posted by
bennjamin
3 spoke non-srs wheel
To take off non srs ( eg si , early vti , breeze etc)
First straighten wheel and make sure on flat surface. Take keys out of the ignition.
Get a flathead screwdriver , lever off the H embelem in the centre of the wheel.
Grab a 19mm deep socket , extension + ratchet or breaker bar.
Take keys out (if in ignition) and LOCK the wheel THIS IS IMPORTANT
Then undo the 19mm hub nut located down the centre.
Pull off wheel slowly , done.
Install new wheel....if aftermarket install new boss kit then wheel ontop etc
