good luck finding rear and front bearing for them ;)
guess i better start huntingQuote:
Originally Posted by from h-t yo
eBay ftw everything for Honda is mass produced in the states... but seriously though my mobile mech has them. vinny if you need em i'll give you his number, prolly just sell it to you.... not from honda but oem
i learned how to do em after he charged me $300 total for parts and labour the first time... little did he know i watched soooooo carefully hehehe
just a precaution really, got the brake setup in my backyard in pieces so i got like 2 weeks to figure out how to pull it apart and put it back together and make sure its in all working order
any visual cues as to what the wear is like on the wheel bearings?
will fondle it heaps ;)
have to hammer out the studs to fit extended studs anyway so i'll see how i go when i pull them apart soon
just thought it would be a good idea to replace the bearings while its all out of the car and not in use at the moment
you need a press to remove the lug nut studs?
I used a old lug nut and put it on the stud and tapped it out with a hammer with some wd-40 to lub it.
Is there a trick to remove the lug nut stud? im having a hard time trying to free it from the hub. sorry its abit off topic.
nah ron no press here :) was just going to take it apart and get someone to press out and replace the bearings for me
if i had a press then i wouldn't care :p
came pretty close to buying a 6t one for about $160 but decided against it
been doing a bit of research on diy bushing replacement without a press and theres a few methods which are interesting(saved in pdf, pm me if you want them)
no need for a press with the studs, just a hammer like you have
check this place for a how-to on removing them, i was going to post it in your thread but i got lazy to find the link :p
