seconded
seconded
ok scott..go with urs..but u'll have to enlarge the pic to almost size of A3..then smooth the lines and even them out..otherwise i can't cut it into the sticker..and if the lines are like 1-2 mm thick only? then the sticker will most likely come off over time...so have to thick lines or no lines...plz get it done by sat then i can print it..i dun wanna delay anymore...thx
ill give it a go...ill just enlargen it and see how it looks and send it to ya.
1st stands out more
as in spoons first one?
still waiting for ur final draft scott
YALLLA hABIBBEEE
pick 3... but rkn it would be just that lil bit cooler if it had a oem rear wing on it =)
scott...if u r still doing this...u need to take out some lines...there are too many....my friend tried to cut my version out...took 3 hours to get the system right coz even the lines on mine are too thin...so if it is the current pic..i can tell u..impossible to cut out...
ppl remember this we are not printing a sticker that have the image DRAWN on it, its a one color sticker that CUTS out like the image....so when u stick it on ur window..its just the white sticker..and the background is black to reflect its content...
getting it done guys but not easy wen the computer is in service so using an older laptop BUT with a newer version of photoshop...im deciding to use Spoons sticker just adding a door into it.then itll basically look like mine...its to much f"ucking around if i get rid and add lines to mine cause in the end its wats easiest to cut out and spoons will be easiest and with the door itll look good.
I like no.3 cause its got awesome detail but i want that sticker so damn bad im willing to settle for no.1 :cool:
yeh its hard for no. 3 to be printed so we may have to go with 1 or 2. spoon u needa send me urs with the grill cause the one u sent me had no grill and ur grills smooth. cheers
