oil filter has a inbuilt sealing gasket.
but it can be caked onto the block due to heat so it rips off.
Suggestion but not sure if ideal, use a steam jet but cover your important components from moisture damage.
you can use degreaser on the motor and spray it off avoiding the alternator, battery, sparks air filter etc though i prefer to use a steamer
all you need is the wipe down your oil filter so there isn't residue and use your clean hand to turn.
that's how i got mine out after a few turns, which was on pretty damn tight.
was gonna mention this too. there is an actual tool made that fits perfectly on the OEM honda oil filters. otherwise, go to any auto shop like supercheap or autobarn and u can get the universal type oil filter tool that fits on a socket. but, as others mentioned, just lube up the O-ring and only hand tighten. should be a lot easier next time and dont need to spend $$$ on tools u dont really need :)
If you get the filter perpendicular to the mount and half turn in reverse and then turn forward you should be able to get the threads to match everytime, sounds like you arent putting the filter on an slight angle.
If a filter removal tool doesnt work theres always the handy long screwdrivers straight through the filter casing. But make sure you pierce through both sides of the casing and center of the filter if you use this method and then use a shorter screwdriver after the initial spearing to turn the filter.
I actually find it easier to take off the drivers front wheel and go through a small gap through there. I couldn't get enough leverage by going under the car =/
after removing the old filter run your finger and or a rag over the filter sealing mount on the block this way u are sure that no debris is left on the sealing surface for the oring seal. and use the oem honda filter with a little fresh oil on the oring and thread on the filter.
paul
