Change the fuel filter under the Rear seats. It probably clogged with shit fuel you put in yu cheap b@5tard.. LOL
U guys recon i should try the fuel additives first???
No, get your filter replaced asap. It's probably clogged. I know, I had that problem when I got my S. Mine cut out at 4000rpm.
If you drive it slow and rev it all the way, you'll make it pass 6000 rpm. Do it again and rev it hard, and you'll cut.
Change-your-fuel-filter.
genuine honda fuel filter for a dc5 should cost only around 90 bucks. get it done, won't cost you an arm or a leg :thumbsup:
UPDATE GUYS!!!!!!!!!!!!!!!!!! my tank is 1/4 tank again, and the same problem is HAPPENING!!!!!!!!
I called honda honda to ask for a fuel filter and they said 90$ plus 120 labour because they gotto take seats out, and get into the tank, cause fuel filter is in the tank etc. so around $200 all up. not to bad. The guy at honda said, because my car had the 80,000km service, it should have already had the filter replaced. So they guy said it could be the way they put it in, and it could be loose?????????
Anyways another thing i noticed is that now, when i turn the car on the ACC position without turning the engine on, I HEAR A NOISE COMMING FROM THE FUEL TANK, LIKE A HISSING NOISE LIKE AIR IS LEAKING OUT Of A BALLON OR SOMETHING!!!!!!!!....... WHATS THAT????????
I GOT MY FRIEND TO TURN THE KEY INTO THE ACC POSITION AND I GOT UNDER THE CAR, AND ITS DEFINATLY A HISSING NOISE LIKE AIR ESCAPING COMMING FROM UNDERNEATH MY CAR COMMING FROM THE FUEL TANK AROUND THE DRIVERS SIDE ISH......
Can anyone further help me to my problem?????
My car just ran out of warrenty. If i extend my warrenty, will it be covered????// i'm thinking of extending my warreny if it covers this...... WHAT U GUYS THINK????
That's probably just the sound of the fuel pump priming up. You should hear the sound and then it stops.
But WHY don't I it when the tank is full???????
Trust me, i've heard tanks priming up, and this is like a BIG ASS HISSING noise comming from the tank. and it doesn't stop, it just keeps on hissing, till it slowley, very slowley fades away.
u recon i should extend my warrenty?
You should have gone to the dealer on the 19th of September when you started this thread. Extend the warranty if you feel like it.
