Originally Posted by
string
Which calculator did you use? The mfactory gear calculator reports ~3233rpm @ 100kph for a 96 ITR transmission.
2800rpm is too low for an ITR @ 100kph. Assuming a 23.4inch tyre height, 4.4 FD, 0.848 5th gear, 100kph = 3324rpm. A 0.878 5th gear from a VTiR/GSR gives 3084rpm. A non-vtec S80 gives 2700rpm with the longer FD and 5th.
My non-vtec B18A does 110 at just under 3300rpm indicated => calculator (excel) reports ~3200. This is a higher rpm per unit speed than your "ITR" transmission. Suffice to say I there's something fishy going on.
I don't think you're in the clear just yet.
