Noobie. Mini with a Vtec JDM B16A
Quote:
Originally Posted by
Renaissance_x
I think its amazingly light.
And mine is pretty loaded inside with current day features, stereo system, central locking, full dash, door cards, front and rear seats and a boot lined with mdf and carpet so imagine if I stripped it all out......easy 200 kegs could be removed.
http://uploads.tapatalk-cdn.com/2016...fd296a512f.jpg
http://uploads.tapatalk-cdn.com/2016...82b5a630fc.jpg
http://uploads.tapatalk-cdn.com/2016...b58969e4cd.jpg
Daveho1
Very nice, so when are u buying a supercharger? í*½í¸œ
I actually have an Eaton M45 supercharger which was mounted on my mini engine but I just don't have the room under the bonnet with the B16 installed. It was a struggle getting it in with the mini engine.[emoji853]
http://uploads.tapatalk-cdn.com/2016...bb4d595065.jpg
Progress on the car at the moment is a bit like building a house. Right now I'm at that stage where heaps is getting done but from the outside it looks like nothing has changed.
Brake lines done. Some creative bending to make it fit.
Drive shafts together
New wheel bearings installed
New brake discs
New 4 pot minisport calipers
Suspension fitted
http://uploads.tapatalk-cdn.com/2016...1135bb1fa3.jpg
http://uploads.tapatalk-cdn.com/2016...254246556f.jpg
http://uploads.tapatalk-cdn.com/2016...c7d6c6a6b3.jpg
http://uploads.tapatalk-cdn.com/2016...c62c70b74c.jpg
http://uploads.tapatalk-cdn.com/2016...b3c001cb82.jpg
Bit by bit it is still coming together......slowly.
After reviewing the feedback on some other mini forums I decided to modify the accelerator pedal to reduce that on/off switch feeling that people are talking about. I took an inch out of the top and added it to the bottom and raised the mounting point.
I extended the short shift Honda gear lever and installed it for the last time. Hopefully.
Radiator, wiring and a few other bits and pieces installed.
I also purchased a set of minivation bonnet hinges to make it easier to work on the car in the future without removing the bonnet.
It's off to get the exhaust done now.
http://uploads.tapatalk-cdn.com/2016...21d40424f2.jpg
http://uploads.tapatalk-cdn.com/2016...6e92961b7e.jpg
http://uploads.tapatalk-cdn.com/2016...0caac4b035.jpg
http://uploads.tapatalk-cdn.com/2016...6836d2901e.jpg
http://uploads.tapatalk-cdn.com/2016...a3f843bc46.jpg
http://uploads.tapatalk-cdn.com/2016...c9d101cd9a.jpg
A few more adjustments.
Brake booster moved to the left to give the dizzy some more clearance. Much better now.
http://uploads.tapatalk-cdn.com/2016...321d238baa.jpg
http://uploads.tapatalk-cdn.com/2016...12a9a56792.jpg
After taking the exhaust off to fix one of the studs, I learnt why I should have went for the ceramic coating. Bloody fibre glass wrap. Itchy fingers. Note to self.....never again.
So, ceramic coating done. Looks great but won't be really seen when the front grille goes on.
http://uploads.tapatalk-cdn.com/2016...05a503dfe7.jpg
And with some playing around with the Autronic ECU it now runs.
I still have to sort out a few things like the noisy IAC valve you can hear before the engine starts and in fact over the top of the engine. Some ECU settings will fix that when I work it out.
https://vimeo.com/174102013
Now to get everything else sorted like bleeding the brakes & clutch and hoping for the best.
Also still need to tidy up the wiring and put the dash back in. Relocate the subwoofer and amp now that I have added a second fuel tank.
Set up the suspension and wheel alignment and the list goes on.
Definitely. Looking forward to getting it on the road now
There is a guy in Lilydale that I have previously used to tune my ECU. I also have contact with the support person of Autronic who will assist with some of the setup to maximise power and drivability around town.
It's interesting to see the comparison of the B16A (blue)vs the supercharged 1275 mini engine. (Red)
Vtec kicks in at 5500Rpms which has been setup to ensure there is no dip in power.
Pretty straight power curve.
http://uploads.tapatalk-cdn.com/2016...545c7bbd28.jpg
Today I achieved what I set out to achieve 18 months ago........to have a B16A powered round nose mini that is road registered in Victoria.
