lol
Maybe so, but good luck with JDM EVO/STi's/GTR's.
lol
yeh but face it integras shouldnt be compared to things like evos stis and gtrs..
because there not anything like em
closest thing is that they all have engines.... and 4 wheels
those cars have turbo, 4wd, newer technology, bigger displacement, etc.
there nothing like a integra or any honda car i dnt know why people insist on comparing them to them...
thats how i understood vtec killers to work aswell..
saying that it may aswell be a b18b because its removing the vtec (kicking in) i hate saying that.... (i feel like im gonna have to have a shower and scrub the ricey off me) lmao
so if vtecs on all the time y not just get a b18b???? ie. gsi
With a GSI there is no VTEC function, with VTEC killer cams on a B18C it would have the VTEC function there but the valves would be open 100% of the time so it would be alot better than 'just a GSI'.
come on guys its verging off topic.
All this talk of "killer cams" - this is for worked engines only and not something to compare a Gsi to a vtir.
Horses for courses , a gsi with the same basic work done to it (I/H/E) will be very similar speed and agility to a vtir.
Gsi is cheaper. Older.
vtir is newer. looks alittle better IMO.
make the decision yourself.
The Non-VTEC heads have such small ports you'd be cutting into the water channels before you even get to the flow rates of a stock VTEC head.
Road cars and weekend are not pure race cars: VTEC means you can have a wild cam and head configuration (e.g. stock) yet retain low down drivability. Upgrading doesn't mean you have to remove VTEC - bigger cams come with the low-lift lobe too.
If I took a photo of inside the intake ports of both a B16A and B18A head you wouldn't be able to tell me which one was which - you'll see a valve-stem and that's about it. VTEC lives in the head, not in your intake ports.Quote:
this is how im saying that a non vtec head will flow better then a vtec head just because of the valvetrain construction.
killer cams do eliminate vtec get rid of the whole function completely. They are for track application only. As when you are at a track you are only using the higher revs. Hence being no use for vtec as you don't not require much drivability down low. Vtec was designed so that you can have a power sports car when required keeping in mind fuel efficiency.
Even then you can find GSi's with colour coded side moldings, skirts and lips.
VTi-R dash is black and carpet dark grey, GSi is all lighter grey. This applies to 98+ models at least.
1. different rims size
vti-r 15" alloy rims
gsi 14" normal hub cover heavy rims
2. interior
vti-r black colour interior
gsi black dash but grey front/rear/trims
3. engine
vti-r vtec
gsi non-vtec
my cousin n i have an vti-r 98 n i have a gsi 96 and 95 they all have the same iterior colour..the seats have a different pattern but thats about it...
mate lol after $5k-8K what are you on about? my cousin has a vti-r yeh? stock..and he will tell you himself a modded (i/h/e)= around $500-700) gsi would beat stock vti-r anyday....plus a built up b18c in a dc2 would not be on par with a stock sti...lol maybe in an eg or crx
Sorry but you won't be getting 20kw out of I/H/E on a non-vtec no matter what your cousin thinks. You might be equal with a cam and a tune; wow you can keep up with a stock car that you should have bought in the first place, a VTi-R with type-r cams and a decent exhaust will rape the modded GSi.
Regardless they are both slow as all hell so who gives a shit.
Type R > VTi-R > GSi
As usual these "vs" threads prove nothing that isn't already available in a search, and even they end up the same way as this one.
CLOSED.
