Ahh thanks. Didn't know we could top them up.Quote:
Originally Posted by aaronng
Is that something people have been doing? I wouldn't expect Honda service to do that.
I don't think they would check it even. It's meant to be maintenance free. But if it discharges, it would consume the water to form lead sulphate.Quote:
Originally Posted by yfin
If you do it yourself only fill to 5 mm above the cell plate. This can be checked by using a thin stick wood or plastic (not a pencil) down the cell. DONT over fill.Quote:
Aaronng there is still time before father's day for you to buy your dad that trickle battery charger;) .
Adagio
My dad? You mean yfin's dad? Hehe...Quote:
Originally Posted by Adagio
My dad has his huge ass current selectable charger. It's the size of an old 14" monitor!
Apologies Aaronng I was working from memory. Yfin take note.
Adagio
arronng, people may be waiting on the reply of your new battery.
lol.
LOL! I replied in the wrong thread. I did it in the grounding kit thread.
Update: I just replaced the stock 300CCA battery with an ACDelco 430CCA battery. Changing to a higher rated battery of the same size does not solve the dimming lights issue. However, I noticed that the dimming is not as bad now but it is still there. Guess it's the alternator.
But.... starting the car is a bit easier! It takes about 2 turns of the starter motor to get it started, and so far, there has not been any struggling once started.
Another quick question indirectly related to replacement batteries:
Does the headunit/radio/CD audio system require a code or PIN when the power is disconnected like most radio security systems?
yes, i'm quite sure it does need a code.
if you ever need that code, just call up your honda dealer, and they should be able to tell you, btw, you should of just started a new thread, so people in future and seearch it and find it.
when i installed the volt stabilizer(had to disconnect the battery), I didnt enter any code and the radio just worked instantly. Maybe there is something wrong with my headunit?
maybe euro's are different? or maybe you can enable em or disable them.
The Euro 03-05 models don't for some reason. Even the TSX non-navi audio system require a code.Quote:
Originally Posted by tanalasta
I emailed the dealer ...
'The stereo system isn’t designed to be removed easily and are fully integrated into the dashboard, eliminating the need for a security code'.
Funny thing is that the same applies to the TSX unit. But I guess over there, they steal everything.Quote:
nah i didnt require i code for mine when i changed my stock battery to a yellow top optima D34 battery. it just fits in there but i duno what im going to do when i update my air intake as theres not much room. it took a while to get my drycell battery to get going as it was out of action for about a yr. it was in my 2002 corolla, which had a customed system until it got written off lol. now shes just like brand new. ill post up pics when i get the chance and you guys can let me know what you think.
super charge gold MF55B24LS for $146????
that sounds expensive right?
where can pick up AC Delco or Supercharge Gold for cheaper and price you got it for and which shop?
Thanks in advance. daz
Call 1300 228837 and ask for your nearest dealer. That $147 price is a rip. We paid $90-95 RETAIL from a small auto parts when in Melb for a MF55B24LS.
i did call them up,
the guy goes auto one then i ask for address to closest one and he goes this is only a warehouse and dont have address on me.
bad customer service or something..
I bought the Supercharge Gold battery last week from a dealer in Moorabbin, $110 with 3 year warranty, not bad!
For the Supercharge Golld (MF55B24LS), is it simple to replace the old one? My one is on the way out.. most likely due to me having an upgraded sound system.
Thanks in advance.
simple,
2 10mm bolts - positive and negative terminal.
2 10mm bolts - battery hold
(correct me if i am wrong i am very bad at visualizing)
when connecting battery back, positive before negative.
For those who complained about the k24a3 engine being lazy to start... I have found the solution. A lightweight flywheel. LOL. Just noticed it today. The starter motor spins very easily and the engine starts without fuss.
Still on the original one.Honda service did their test on mine yesterday and said it is just above "fail".HA won't replace it till their test comes up fail.Now my car is over 2 yrs.old i'll have to pay 50% of the cost of replacement battery.HA gives only 2 yrs. warranty on the OEM battery then 2-3 yrs.50%:thumbdwn:
Same thing happened with my last car,it had sound upgrade as well.Battery lasted approx.2.5 yrs.I'll just get one with higher CCA and i'll be right again.Anyone here recommend a good brand and/or place to buy a new battery from?BTW i'm in Sydney.Pricing as well please.
If I was going to upgrade, Id go for something like an odyssey or optima yellow top battery.
yeah, should be able to pick em up for $250, maybe less if you look around.
I think its the optima D51 yellow top / Odyssey 800that is the replacement one for the euro.
Those supercharge gold MF55's are only about $100!
Before you buy, ask the shop if warranty is handled direct with supercharge or through the shop. The shop that sold the Supercharge Gold in Melb handled warranty in the shop itself. So it was all good. With most manufacturers, if you have a return-to-base warranty, it is troublesome.
OK.Got a new battery.Delcor(made in Korea)3yr.warranty.11 plate(OEM one is 9 plate)430 CCA(OEM is 330 CCA).$108.00 installed!Big difference when starting in the morning,it turns over quicker and starts easier now.:thumbsup:
Are Alco batteries any good?
The dude reckons they are good quality 400cca Calcium batteries that rarely fail. They have 3years warranty and most of the returned ones that failed just need a good recharge, then they are good as gold.
Linky http://www.alcobatterysales.com.au/alco.pdf
3-year warranty is pro-rated. Don't rely on it 100% to justify your purchase. :)
I was quoted $155 for the Supercharge Gold. It seems a bit high compared to the price people have posted. If you know of a place in Sydney that sells these batteries cheaper can you please posted their details here. Cheers.
i think the supercharge gold prices have gone up, if you are in the south west give meakong auto spares a call they sell it there.
i think mekong was cheaper but when i asked autoone they quoted around $140ish.
couple of years ago aaronng and euroaccord13 got them for $110 or so but yeh... call around.
Otherwise when you see a supercharge van around, carjack it.... :p and hope they have one of the batts your looking for. J/K
Note: Only reason why i didn't get supercharge gold was that when i called to ask for distributors around they weren't helpful and weren't friendly. Only told me Autoone, asked for other distributors, they said "i dont know".
Thanks Traumatized and Daz.
I was looking at the AC Delco as an alternative. The first local dealer i rang gave me a quote of $170! I will try other places as well but it seems like there's a huge jump in prices of batteries recently.
If you know a place that sells good batteries at a reasonable price can you please share it with the rest of us.
Agree with your 2nd suggestion, self owned and cheaper prices.
Thanks Aaron.
I rang Supercharge head office and the guy (Tony) told me that the RRP of the Gold is $148.50. They also sell direct to the public through their head office at Blacktown (new location). So, expect to pay ~$150 for the supercharge gold from now on.
I want to change batts for my gf's Ka.... whats the the address, so I can drop by to take a look?
Ok guys the $150 i've been quoted for the Supercharge Gold is for MF75D23L which is larger than the stock battery and as i understand from previous posts is not right model for the euro.
So, you need give the shop the specific model no. which is MF55B24LS which i suspect will be cheaper compared to the MF75D23L and explains the $100 price people here have paid a couple of years ago.
whats the highest range of the Optima series? one for the CL9 of course. Im after another battery atm.
Are they still having the same problems with the quality issue or has it been fixed?......Aaron?.....LOL..
awwwww, that crap then....LOL.
Is there a battery for the Euro thats like more than 500CCA? or am i just thinkin 4DLULZ.
thats good!
notice any difference?
As above...
I just replaced my battery today for an AC Delco 430CCA Sealed Battery. Part Number: S55B24LS cost $110.00.
Then went down to my friendly Honda dealership and they did the "idle relarn" for me. Took about 20mins to do including changing the battery.
Car now idles better, starts easier and feels zippier to boot!
I had a flat this morning. I got RACV to replace it with one of their batteries (I'm a roadside assist member and needed the car badly with no other car to go and buy one).
It's got a 3 year warranty, anybody had any experience with these?
where you guys find these batteries (so cheap) from?
I just help my gf replace her car battery, supergold maintenance free and it cost like $200
Agreed, i only just picked one up from my mate's workshop when i had the pulleys changed.
only cost me $90 for Solite 430CCA.
mm, yeah i got another SuperChargeGold MF75D23L @ Autobarn for $159.
Slightly bigger than stock as its for the 03 model only, but it will fit other Euro models, so you need to lose the bottom battery tray, but its 610CCA. :)
