Yes please take some photos of the clearance between the AC lines, ABS module and the pulley.. It will help give me an idea of how much to grind... :)
I've just installed the J's Racing damper (and a host of other stuff), and although I can feel the car is vibrating slightly more, I can also now hear the engine louder in the cabin. Is that normal?
does anyone have a link to a trader or seller of the Ingalls ETD?
Excelerate at tsx.acurazine.com forums, or http://www.excelerateperformance.com
thanks aaronng...
did anyone find out whether it is compatible with UR pulleys?
ive just brought the pulleys (should get this week) and i dont want to order the ETD if it wont fit (obviously!!!)...
thanks
You have to grind down the bracket(s). Read this to see the potential issue (read every page starting from this one): http://tsx.acurazine.com/forums/show...&page=16&pp=25
thanks for that aaronng, i knew you'd be the one replying :D
i purchased one off the guy today that had been returned because of some of those issues, im not too worried thro, i can make it fit, im not affraid of alittle bit of modding.... plus i got it for AUD$126 landed at my doorstep! :D
thanks again
Im not hearing of any tangible benefits of the ETD as yet. Can anyone post any definitive medium term results ?
Ive had mine in for a while now,
I guess the main benefit is less wheel hop if your trying to launch your car, that being said it doesnt completely eliminate hop just makes it less occurent.
also, it might just be in my head but theres a slight improvement of engine pick up when your foots put down, feels more direct.
There is increased Cabin vibration though, and low speed 1st gear driving can create rather harsh vibration in the cabin.
I agree with the above. Since having it on, I do notice that wheel hop is less - but since I don't drive my car that hard, the added noise and vibration is making me think twice about whether or not to uninstall the ETD - since I enjoy a nice quiet cabin!
The benifits are less noticable wheel hop and vibration can be reduced or elimated by adjusting the ETD to a softer setting.
The pick up feel is more direct when the ETD is set to a stiffer setting, just play around with it to find your best compromise.
For the ETD, I had to grind a fair bit off both brackets to fit the unit... I should have some photos of them... I'll post them up when I find it...
Ive got the Ingalls ETD, i'll try adjusting it, might be set to harsh
I dont get "wheel hop" my launches are very smooth. Must be my skill+suspension tune+tyres.
im only buying it for the bling :p
And put diamonds on your rims to make it more bling bling too...
I found the photos of the modifications I did to the Ingalls brackets.. I'll post it up soon!
You don't need to drain the oil. But make sure that the gasket is still fine and get some RTV blue gasket sealant just in case you need it. You realise you have to remove the ignition coil packs too? Not sure if you have to remove the spark plugs. I'll check.
Edit: You don't need to remove the spark plugs, just the coil packs. Here are the instructions just in case:
http://img87.imageshack.us/img87/779/rockercoverub3.jpg
These are the modifications I made before I sprayed the brackets black to clear the pulley, ABS module, aircon lines and bonnet issues...
There are still issues with the bonnet lining but I cannot afford to grind anymore down...
http://img.photobucket.com/albums/v1.../IMG_1448w.jpg
http://img.photobucket.com/albums/v1.../IMG_1445w.jpg
http://img.photobucket.com/albums/v1.../IMG_1444w.jpg
The cut for the bracket that sits on the sussy tower is angled as well to clear the AC lines...
http://img.photobucket.com/albums/v1.../IMG_1447w.jpg
all of a sudden, the FEELS etd seems like a no brainer :P
Yup, it's the 4 black things under the spark plug cover.
And yeah, you should get the gasket sealant. Seems that you need to use it on certain points of the head. Here are the installation instructions: http://img181.imageshack.us/img181/5...installcd5.jpg (291kB)
thanks aaronng, ill let you know how it goes later in the week :D
No problem. Now back on topic. :)
ingalls etd installed!
im guessing its normal to have alot more "engine noise" in the cabin now? i dont know how to explain it, kind of like i slight whine... im guessing its just the noise travelling through the chassis now?
looks sweet!
Thought that I will revive this thread seeing that I just bought the ETD from Pumped and just took the car for a drive.
Pros:
You definitely feel an improvement in the response of the throttle. I do feel like the car is quicker of the mark and less sluggish. And it looks good!
Cons:
It's not so much the noise in the cabin that bugs me but the vibrations. You feel everywhere, from the steering wheel to the dash and to the seats. There's also a knocking sound from the engine bay that I think is coming from the ETD knocking the a/c pipes. There's too little of a clearance from the ETD and the a/c pipes.
Verdict?
Don't know if I'll keep it on the car, or should I say, don't know if the wife will let me keep it on the car if it's going to be that noticable in the cabin, but will give the damper a tweak and see if it gets better.
this is really noob, but what does a torque damper do?
how did you have knocking on the the AC lines?
the only problem on mine is that the brakelines were in the way of the chassis/etd bracket side bolt so i added rubber hoses on the brakeline to reduce stress.
damn i duno why but i don't feel too much of an increase in vibration, it is noticeable though compared to stock.
There is a lot of variation in the A/C lines and brake lines as they are bent and assembled by hand. Take 2 Euros and it is very likely that the AC and brake lines are routed with slight differences. I have seen one Euro that could not fit on the Cusco strut bar no matter how we moved the A/C line. We had to grind down the Cusco's mount.
It is possible to adjust the installation of the ETD to reduce vibrations, i found at some stages vibration was quite bad and start up caused a shake through the car, adjusted slightly and it reduced it dramatically
Also found good clearance with the A/C lines etc in my euro :( they must all be slightly different as mentioned by aaron
bummer, i had to grind the side of the bracket cause it wouldnt have cleared the UR pulleys.
otherside on the chassis wasnt too bad only had to take precaution of the brakelines.
but yeh i'll see how it goes.
damn the ETD restricts you from removing the chassis to engine mount gounding wire cause its so phat.
unless you remove it or you have a slim socket extension.
btw aaron are you running the etd at the stiffest setting or softest?
Did some re-adjustments to ETD and made it a little softer and now the knocking sounds are gone. Unfortunately it isn't as responsive as before cos it's softer. It's really a trial and error exercise to get it right.
Definitely thinking about grinding the plate a little to clear the a/c lines, damn, taking it out is going to be a pain.
I'm thinking of fitting one of these to my car and I've got UR pulleys installed. What damper & brackets do I need to get to ensure it fits?
Yeah, time to break out the dremel. Just got a 2nd ingalls ETD kit just to replace the damper! About the same price compared to buying the damper unit on its own.
Dang that doesn't sound like an easy install at all. It'll take a fair bit of trial and error to get it right then.
