ive got N+ in my EK. lowers the car to a decent height, more than tein SS i believe. can be set quite soft or rock hard. if ur worried about body roll invest in sway bars. coilovers wont fix it.
ill take up that challenge
my coil overs took out heaps of the body roll.. more noticeable comparing them to my 22mm rsb setup.
springs + standard shocks = not much of a difference in body roll
springs + standard shocks + 22mm rsb = a big change.. less body roll
tein HA + 22mm rsb = same shit really abit more stiff but similiar body roll
tein monoflex + 22mm rsb = ALOT less body roll more noticeable once the new coil overs were installed less stiff.. spring rate is perfect..
so pretty much if you find a very good set of coils.. i find upgrading the sway to a 22mm one wouldn't be very noticeable.
all in all i reckon if i took outmy sway bar there wouldnt be much of a change..
and ive played around with the height settings aswell.. from normal hieght to very low not much of a difference in handling.
thats my experience anyways.
