True, I'll grab some tomorrow.
How much is needed? 12L?
Is it around $70/4L @ honda?
http://autorepairservice.wordpress.c...at-low-speeds/ so this guy recommends full flush and no drain and fill?
So in that case if i do 1 x every 10,000 k i should be fine
Maybe i should get another 6l and do 3x3 anyhow
is anyone using http://productsforyou.castrol.com.au...ultivehicle/35
would this be better than valvoline max life
Just go with the fluid mention here in this thread
I know it's a good idea to ask about other fluids
But Fredoops has made a list suitable for our transmissions
There shouldn't really be a need to doubt that
Not doubting , he has done a great job on this thread :)
i did a search on different fluids and castrol recommend their fluid in their search for Accord Euro where Valvoline don't.
I did sent email to castrol to see what they would say about this but will see , in meantime i might give Valvoline a go :)
yes it is :-) EDIT: for CL9...
http://img.photobucket.com/albums/v2...er/Capture.jpg
not for cu2 :)
http://i40.tinypic.com/zsok1y.jpg
well... you're in luck...
Redline has a new ATF come out
D6
It's Dw1 compatible.
http://www.redlineoil.com/product.aspx?pid=115&pcid=7
seems that Dw1 is just a thinner ATF cause D6 is thinner than the ole D4.... Might be safer for you to look at DW1 compatible fluids
