Pretty sure ferrari and audi and the like would invest more money into its air/fuel ratio systems than a bulk producing company like GM, a matter of fact i know they do, companies like ferrari use great loads of real life testing, they will put an engine through the worst and make sure everything works proper, hence why you pay that higher premuim for quality, rather than GM that mass produces its v8s making it a cheaper alternative, if you want to call it that... a commodore will last what 10-20 years where in which you will spend thousands every year to keep it alive, a ferrari will run and run and run, yes the parts will be greater but you won't need to replace everything all the time compared and at the end of the day you have a friggen ferrari in your garage which will be classic not some commodore used for ramraids on a local deli.
Also you forget to mention one key thing with all these cars.. weight. It's all good having all this torque and then dumping it in 2 tonne family 4 door car or in the case or a monaro a 2 door commodore:p. OK cost is a big factor ey, pretty sure the atom 500 (another european idea) is cheaper than any 'muscle' car at the same level of performace, yes it dont have 'luxuries' e.g. a roof or windscreen but the topic was best engine in the end. And the atoms engine is based off a motorbike! oh well ive done enough rambling and defending the point euros do a better job in my mind.. still stand by honda have done the best V8 engine though (money being no object that is:P)
