Edit....
(Comment was just spam)
Edit....
dudes.. stop spamming the thread, this one has a specific purpose = POWERBAND/CURVE as a result of camshafts and supporting modifications...
no cam and full motor specs put it in the dyno thread and discuss there.
besides US dynos calculate 15% drivetrain constantly. whereas afaik ours are configured based on fwd/rwd/awd from ~20%
Leonards EG is a purpose built engine for the application of reliable racing with excellent throttle response, torque, and power across the selected rev range, and im sure its still got plenty in it.
What im also not saying is power figures of 150kw cant be done cheaper either.
But ill still be very impressed seeing 170kw out of that set-up on pump, but not putting down the engine or combo, just speaking from what ive seen.
Out of interest, if you have your head flow figures available, what are your exhaust ports flowing?[/QUOTE]
213 cfm @28 inches of water
Slaz i agree it will be hard to get those figures on pump, but we will see what happens.
Anyway lets get back on the topic of this forum.
This is King motorsports setup in the US
Here it is again:
Kingmotorsports built bottom end
B20z block
13.1:1 compression 93 octane
Bdl block guard
Mahle 3cc 84.5mm pistons
Stock rods bushed small ends with ARP bolts
Kingmotorsports balanced rotating assembly including flywheel and clutch
Type R head street ported by PURE TUNING
stock Type R valves
supertech springs
crower cro-moly retainers
Skunk2 Pro 2's degreed in at 55* opening on the exhaust@.040 valve lift
Skunk2 Cam gears
Type R intake manifold stock matched to TB
Type R throttle body bored to 64.5mm
RC 310's 96% duty cycle
DC jdm 4 to 1 header
Skunk2 Mega powerR exhaust 2.75"
Hondata S200
Link
http://www.honda-tech.com/zerothread?id=2286082
read this link, he allmost got the work to do my head, but i went to the US
http://autospeed.com/cms/A_2498/article.html
nice link.
but this is really the wrong thread.
what are the average torque ratings for a stock b18CR with bolt ons, and same for a k20? from what Ive seen b18c's are round the 160nm mark? and what are the k20's? thanks
Its hard to compare with the 6 speed gearbox
The piston speeds are infact that high but its working isnt it, but saying that, most of these K24 engines going around are in street/drag orientated cars, dare say if you were hoping to have this set-up as a curcuit engine and have it produce similar power at sustained high rpm for long periods of time, the chance of failure is much higher hence why the curcuit k motors out of Japan or the U.S use the OEM 2.2 crank like what is suppplied with the Toda 2.2ltr stroker kit for the k20 motor instead of using the k24 bottom end.
In the U.S they are starting to mod the turbocharged Honda RDX crank to work in k series engine as its of better quality, OEM manufactured and doesnt come from an engine that uses balance shafts. ;)
Hope this will help out guys wanting to go down the b16a route. Dyno sheet will be posted up soon. Dyno ran out of paper :(. Tuner for both setups DD. same dyno was used on both ocassion.
Engine - BYP B16a (P72 head port/valve train)
Displacement - 1598cc
Bore - 81mm
Stroke - 77mm
CR - 12:1
Camshaft - BC spec 3
Camgear Settings - BYP
VTEC X-Over - ..BYP
Gearbox -4.9FD B16a
I/H/E -Skunk2 manifold + 70mm t/b/ BC headers/ 2.5'.
ECU - Hondata S200
Peak power 123kw atw
Engine - BYP b16a (PR3 head -stock ITR head with valve train)
Bore - 81mm
Stroke - 77mm
CR - 11.7:1
Camgear Settings - ...BYP
VTEC X-Over - ...BYP
Gearbox - 4.9FD b16a
I/H/E - A-Sport ITB 44mm/ Toda rep style header/ 2.5'
ECU - Hondata S200
Peak power 117kw atw
Between the 2 setup's we've change the intake system (ITB), different head (stock ITR head), and different header design. We manage to pick up a massive 12-18kw gain in the midrange. Both setup had thorough tune so it wasnt just a quick slap tune.
http://i4.photobucket.com/albums/y13...9/P1017852.jpg
wow nice mods
