Originally Posted by
vyets
Sorry but people need to learn how to calculate offset as well, half the sizes people ask are almost the same thing.. can't be spoon fed everything man. Just look through the thread and you will get a general idea if what kind of sizes the car can handle I mean the thread is 20 pages long...
The front guards can handle anything under a 8" wide with 40 and higher offset, that's with a roll.
The rear guards can handle anything under a 9" with 45 offset and just a roll.
That's with full sized tyre and natural camber.
Obviously you can go wider but you will need to sacrafice tyre size.
At the end of the day, like I've said many times you ALWAYS need to roll your guards, once you lower your car even on stock wheels there's a chance of them getting clipped and demolishing your guard.
Best way to find out if a rim will fit is buy it, test fit it then you will know what tyre size you can run and how much work you need done too your guards. Diffrent tyres have diffrent sidewall thicknesses so depending on the tyre you get it will change your fitment as well. There's way too many things to factor and it's best to get out there try and learn.
