Hey guys,
Anyone seen or got a pic of the DA with a CARBON FIBRE ROOF, BONNET and Mirrors?
Does it look any good?
Hey guys,
DA9 Radiator.
Guys, we have a b18cr in an ED9.
B18's have 32mm radiator hose inlet.outlet.
our b16 ef8 radiator is blocked beyond repair.
have replaced it with a normal ED civic/CRX radiator.
Problem is that all the ED radiators have a 28mm hose inlet/outlet.
I've been told that the DA9 radiator has the 32mm outlet/inlets and also fits the ED/EF CRX chassis.
Can you DA9 guys please go out and measure your DA9 radiators for me please???
I want to have confirmation before I go out and buy a DA9 radiator.
Rep given to helpful information.
thanks
you only need eg6/dc2r lca's for DC2R suspension not DC2. DC2 rear suspension is a straight swap (NB: da9 rear dampers are alot longer than dc2 dampers).
Both DC2 and DC2R front suspension requires the front drop forks from a dc2r or a dc2 to be fitted to a da9.
thank you.
i got sun damage on the roof, cbf respraying so i figured why not try sumfn different? im after opinions.. ?
DA9 & ED/EF radiator is close enough to the same size.
wow... i didnt know that? sorry mate but how would you know??
spend $100 and buy this http://firesport.com.au/3m-dinoc-car...--ad163440.htm then stick it on ur roof :)
