Originally Posted by
Rudy
One can buy each item seperately as well. So, you can start with just the camber arms, and then if you find this doesn't get you within OEM alignment specs, can then buy the toe arm etc later on. But given that the full 6 arm kit (ie 3 arms each side) from J power is so close in price to the 2 arm kit (1 camber arm each side) SPC kit, I suggested to just get that kit, and you will be assured that they will be able to get you into OEM alignment specs. (that also means only paying for one alignment as you dont need to get more arms later on and re align as well as less installation costs).
