Whiteline reinforcement kit and 22mm rear sway bar installed
http://img.tapatalk.com/79d8caf7-8476-53b9.jpg
C pillar brace installed
http://img.tapatalk.com/79d8caf7-848c-2290.jpg
Dis-agree, ive got set of buckled rims sitting in the garage, similar to whats shown, whilst drive at 100kmp/h vibrations is terrible! low - mid speed range its ok, noticeable but bearable to drive
Most rim repairers places would attempt to fix it, but always 50/50 that it will crack if tried to repair an get thrown away, happened to me once
when i was driving home i could feel a little vibration on the steering wheel while only doing 60-70kph,when i got home i saw it and jacked the car up and spun the wheels to see and you can just see it straight away it was stuffed,also to i need a new wheel alignment the steering is out from that.
$283 + $10 shipping for Whiteline reinforcement kit and 22mm rear sway bar from Online Peformance in Melbourne. Difference: not dramatic as I'm already on coil overs but theres now a tendency to oversteer lol.
$60 shipped for c pillar bar from eBay USA diff: prob none just there for the bling, have rear strut tower bar installed in boot too.
With everything in rear end feels significantly stiffer.
pretty cheap nice buy man,22mm is a bit big dont you recon ? mainly for the track you would use those sizes? ive only got a GLI 22mm on the front and a EM1 stock rear sway bar 14mm i think on the rear and it oversteers if i push it, cant imagine how much oversteer you would be getting with all that work.
Dont those whiteline sway kits tear the subframe out of ek's?
nope, this is the revised version (1 piece bar runs from 1 side to the other) previous 2 piece kits would tear the subframe straight off!
http://i2.photobucket.com/albums/y7/nt_889/P1010853.jpg
certainly doesn't look like a one piece bar.
You have pillow ball mount each side (?) and bar in the middle, hex adjustments on either side.
if it is indeed pillow ball, would be @ least 5 pieces there, not one.
if not pillow ball, then looks like 3 piece bar.
hes talking about the brace dude
You need to learn to read m8 even a preschool child could work out that the pic you just referred to above is the Whiteline V1 2 piece mounting kit with a rear lower tie bar of which I used to illustrate their original design, the pics of the1 piece bar I installed is a few posts above...
WATAJK!
