18x8.5 +35 18x9.5 +38 will this offset need spacers
try this out
http://www.1010tires.com/WheelOffsetCalculator.asp
enter you current fitment and desired fitment, and measure how much clearance you have at the rear of your wheels between the strut and wheel and go from there.
I did a quick calc, if your currently running 7.5" with a 45 offset and your going to 9.5" 38 offset, you have move 18mm closer to the strut. So depending on how close you are to the strut before, you may need a spacer (5mm would usually do the trick), but then you may have to think about negative camber also, as this will effect your clearance to the strut.
I know on my fitment i was only 5mm closer, which didnt cause an issue, even with natural camber slammed (which is around -4.
ok cheers guy
does ne1 know wot the factory offset on lux rims are??
ne pics of ur setup guy?
do u think i can get awy with natural camber on the fronts 18x8.5 +35
stock '05 lux has 17x7 et55 if I remember correctly.
18x8.5 +35 you have to run 225's or smaller with natural camber and front guards need to be rolled.
18x8 +35 and 18x9 +36
Ive rolled the rear and tucked the front liner still rubs abit on the rear bumper tabs.
http://img267.imageshack.us/img267/2409/img8305h.jpg
http://img256.imageshack.us/img256/3406/img8287b.jpg
off topic but nice car, what exhaust you got?
WOW ! that hotnesss perfect stance !
post up more pics and spec euro owners
nice!!
front camber arm??
no shots of the fronts with wheel straight/not turned? hard to tell wat the front looks like in those shots.
