RB20 turbo's are T3, I wouldn't use this turbo personally. Try and look for a T28 ball bearing.
RB20 turbos are T28's with T3 flanges. I use one with no problems
lol .. tight budget man .. t28 ball bearing will be out of reach for that guy :p
yep serpo is right, its due in on monday...
i rekon the t04E is a nice turbo from what ive read, for quick spool but i rekon itll run out of breath at about 5,500 :)
from this projects experience ive learn if your on a tite budget always go the t3 flange direction, heaps of supply and support online, but if u can afford to go custom, then the world of turbos is your oyster (however the spelling goes)...
im getting rid of the downpipe i ordered of the internet for a t3/t4 turbo as i dont think itll fit this rb20 turbo...
im assuming these turbo run t3 feed fittings. So since i ordered td04L fittings and lines already ill just have to replace the small fitting to the turbo feed
remember rb20 uses the flanges off a t3, the down pipe SHOULD fit. not 100% sure though, have u thought about mayb a rb25 turbo, haha thats a t3 with t3 flanges :D
rb25 is tooooo big and laggy i wanna keep is small but not too small :)
ill try this abit then once it works, ill experiment with other setups :)
your rb20 did it have 5 or 6 bolts? because my downpipe is 5 bolts and i thought rb20 had 6
it is 6 but its still the same flange.... wouldnt be hard to modify it.
and a t3 isnt that lagg, my old t3 use to kicks in around 2500-3000 max. my rb20 turbo kicks in around 2000.
man thats pretty good info, well fingers crossed till it gets here monday :)
for some reason it doesnt look like a t28 to me, but nething would do, as long as it fits what i have
heres a pic:
http://www.boostcruising.com/forums/...post&id=308198
looks tiny
what happened to your td04?
wow so small and cute
will be able to hide that no problems!
