im in the same boat but im 225/35/20 and i want to put h&r's...
i think with such a low offset the wheel or tyre will hit the fender when the car hits a bump... anyone care to elaborate?
If you read in a few posts back, hondar (JDM concept) said +38 -+45 in the rear will be fine and front +40 will be fine,
So +35 all round will need to roll the guards all round definetly, with a tiny drop from eibach or H&R springsd as you guys will get no natural camber in at all, the wheels will actually stick out past the fenders especially the fronts. meaning it will look unko with out a big drop, better off to choose a higher offset if your not planning to go very low.
oooo ok thanks man
hi guys,
will 19*7.5 +45 fit CU2? What tyre size will be the best?
Thanks heaps...
he used 245/35/19 load rating 93, Dunno what brand.
All load ratings will be the same on each diffrent brand tire in that size.
isn't 245 a little wide for a 7.5 inch application? i'm pretty sure 245 is like an 8.5 to 9.5 range... better stick with stock tread width 235 imo
i highly doubt cops will put over the new euros anyways, but since my load rating for my tyres is 95 only, i'm in the process of getting custom tyre placards
^^^ That what I thought as well... but tyre stores seems to say its ok... :S
custom tyre placard? I thought the load rate was printed on the tyre's wall?
