If you know which fuse to pull, then yeah, pull it. But many people are not as technically-inclined, so it would be easier to tell them to pull off the negative terminal, rather than try to guess which fuse is for the ECU.
Well the location and the fuse number is in the Car manual.
i took out my battery because it was late at night and i couldnt be ****ed opening the fuse and looking for it
dc5 uses small fuse. + i made a post earlier about the bloody fuse box pictures! i as it doesnt say which fuse is which in WRITING!
anyone know how to get this !
there are 2 ways to reset the ECU,
1. to take out the ECU fuse next to the battery
2. unplug the -ve terminal of the battery and leave it there for 10-15 min.
Any pics or examples of tweaks ppl did to fit the Intake better, tighter padding. ect.
heres some sounds :
click here
hey guys, does the Gruppe M Ram Intake come with an air filter or is it just an intake box? sorry Im a noob.
niicceee...cheap too
It comes with a K&N Cone filter ;D,
Basically Comes with:
Box, Heat Shield, Scoop, New Cowl Top and all the screws and oil piping
Everything you need to get you going ;D
