Could you be more specific? Did you just put it on jack stands and drop the linkage out beside the exhaust?
did a compression test, 3 cyinders have an equal 210 psi :D cylinder one is not so far off with 30 psi.... hmmmmm
Which area did you get done in?
I copped one Friday night 10 minutes after work at 11.10pm!
I also measured their height test wheel, it ain't 100mm
well heres a few snaps from the ozhonda meet if no one got to see
http://img.photobucket.com/albums/v2...IMG_0906-1.jpg
http://img.photobucket.com/albums/v2...cture001-2.jpg
http://img.photobucket.com/albums/v2...cture002-2.jpg
http://img.photobucket.com/albums/v2...cture003-1.jpg
http://img.photobucket.com/albums/v2...cture004-1.jpg
http://img.photobucket.com/albums/v2...cture005-2.jpg
How do they test height anyways?
100mm wheel on a stick and roll it under car to see if it hits anything?
Yep
It's like a Long piece of wood, a wheel that white in middle and black on edges ( its like the down hill cart wheels but very small) and they just shove it under a car and make sure it hits something just to prove you wrong
When I lowered my car, I used a measure tape to measure a piece of wood, 11 cm give or take,that wheel the cops had had at least 2-3 cm more that didn't clear, so how can the algal height be 100mm??
11cm from my rear resonator ( ek9 b pipes have 2 resonators) one right where the axle flange is) that's my lowered point ATM, that's excluding my beaks bar cause that's low an not factory
If you definitely measured from the lowest point on your car and you're certain you're at or above 100mm from the lowest point, you were either on uneven road, or the cops were just pricks. I'm willing to bet it's the latter. If you can easily get the defect cleared, do it, then put it back again and pass them off as wankers.
was around chapel st, seeing my mate before he left australia... was pretty dog what they did as they waited for me to come to my car than talk to me...
lucky they didnt fined me, although they said they were gonna but saw the uni sticker LOL....
coulda been worse, they coulda done the exhaust, hid and few other things, but other wise, defect for ride height is easy to clear, jack up the coils, clear 100mm, easy :D
