My car is electric. I have über small balls
Plus my car looks like a 4x4 compared to some on here.
Über mega small ball
Guy offered weekly payments
Why not LOL
What are these BIG plans you have??????
Me and lolmclol are getting married guys!!!
Nah I'll post pics when they're on the car ;)
I briefly popped by the Melbourne Car Meet at Carribbean Market, today. It was a bit quiet and the cars were a bit too spread out.
Did anyone go?
Stevo is OCD. Just let him do his thing lol
Most expensive mod for me was my coils haha, rims i got for ridiculously cheap
That said, if anyone finds a set of used, cheap semis (or something along the lines of federal 595 or a ad08) in 215/45, pls let me know :)
Got left with 5 PSI in one tire yesterday
http://i.imgur.com/0y885K3.jpg
Hey guys these coils say FD2, i was wondering if they would fit in the FD1
https://fbcdn-sphotos-g-a.akamaihd.n...01035306_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.n...85623721_n.jpg
hey wait - is that a can top in your wheel hub?
that's such a cool idea!
The coils will fit
Both same for fd1/2
@jprak Thanks man!
unique idea for sure
My centre caps are ugly as shit so i just left them empty haha
got that fake carbon look on it, yhnh
http://949racing.com/images/products...r_tungsten.jpg
Anybody selling rear coilovers in QLD?
picked these up yesterday, makes it easier to see if the wheels are running low on psi
http://i.imgur.com/ZXp8Kbr.png
http://www.blushing.co/images/blushi...g-rid-of-1.jpg
oh you guys ;D
<3
Question:
If 1 of my rear license plate bulbs keeps burning out. Is that a short?
And would it be due to the fact I'm using LED lights (less resistance)? 1 seems fine, but 2 bulbs have busted on the other now, they work for a while, then just blow.
If it's a short, how abouts do I go finding where it may be coming from? thanks!
What's the best bang for buck stereo mod? I just want more bass really and am a noob at ICE. (But meth I'm an expert)
Planning on keeping the OEM Headunit?
If so, And you want more bass then get a Amp + Sub.
Since out headunit does not have output RCAs you will need a low level converter.
Some amps have them built in, Making life alot easier but you can just pick up a branded one for about $100
If you plan on changing the headunit then wait and do it all at once. Saves money and time
Yeah, gonna keep the head unit. Is that a big job to fit an aftermarket one anyway?
Amp and sub sounds good. I don't want ear melting bass... Just some more oomph. Would a head unit change give me that much extra bass with the stock speakers??
I remember when I first joined here there was a stereo cheat where you held down/pushed certain and it made the stock system bump more. Anyone remember what it was??? Cause since then I've had the battery replaced and doesn't that reset all settings?
So many questions. Sozzy. Lol
Changing the headunit alone without a sub will not make the stock speakers pump out more bass.
You might get a bit better sound quality but not more bass. If you're not a massive basshead then I would recommend something around the 600w RAMs range.
Most amps have a Sub control now anyways. You can adjust the bass like the volume knob
If you buy an OEM fascia kit, it's a pretty straight forward job to switch the head unit around - a couple of hours, tops. eBay kits are luck of the draw. Some of them fit well, some of them don't.
Upgrading the head unit will give you an overall cleaner signal and delivery of sound. Bass will sound a lot better, and you'll be able to adjust more bass settings. For example, on my stock unit, I had bass turned up to +4, volume on 8 to 12, and when I played a bassy track like Markus Schulz - Love Rain Down, I could hear the speakers popping and bass sounding like balls.
I replaced it with a $200 head unit and the output was so much better at similar volumes. There were more bass customisations and it allowed me to really enjoy my music more.
In saying that though, if you turn it up really really loud (equivalent to volume 15-20 on stock), it's going to struggle, and that's when you'll need a sub.
If you're only out to achieve louder bass, but not cleaner bass, go for the sub.
Otherwise, upgraded head unit is best bang for buck as it improves overall sound quality.
Hey guys need help ASAP !!!!
took out stock strut to put in coil overs but the assembly is stuck in POSITIVE CAMBER AND I CANT PUT THE LAST BOLT IN.
https://fbcdn-sphotos-d-a.akamaihd.n...21681075_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...76154133_n.jpg
People been saying pull out the disc and rotate till you hear a click to allign the CV splines but its not working!
Use a jack to hold the disk and lift it so you can bolt it
Think that's what I did I think
Yep CV shift has popped out, if you put weight on it ?? Then you may have put a burr on the end of the shaft and you will find it almost impossible to get back in ! CV will need to be removed and serviced, if you didn't put weight on the wheel then get somebody like a mobile mechanic to drop in an fiddle with it, they should be able to get it back in.
dudes!! thanks so much for the info and advice. love you ozhomos. xoxoxo
i think i will go for a head unit upgrade as it sounds best bang for buck.
what do you guys have? and pics??
thanks again!!!!
sorry if this should have been in the audio section.
changing the front speakers to aftermarket would be fairly cheap yeah?
@stevil, The CV shaft spline popped out, posted this picture on the mighty car mods forum and someone came over at 2am in the morning. Its fixed now !
Yeah it'll range from $80 - $200 depending on quality.
JB Hi Fi have 30% off car audio until Sunday so it's a good opportunity to pick something up. If you change your mind, just return it later :P
If you're working on a budget, start with the head unit first and if you're still not satisfied, update the speakers to something that'll push out more air/more bass.
I haven't opened up my door trim to check our speakers, but on my girlfriend's GD1 Jazz, the stock speakers were as fragile as a piece of paper and the quality reflected that, so there was an urgency to replace them.
thats what i was thinking. although the hybi comes with different seat and all the fruit im sure the speakers are they same doo doo paper thin speakers.
gonna hunt for a new head unit first for sure.
thanks again dude!!!
2006 HONDA CIVIC 4DR SEDAN WITH 1.3L HYBRID ENGINE AND STANDARD AUDIO SYSTEM
Speaker Specifications
Location Size Depth
Front Speaker 6.5 3
Front Tweeter 1.25 2
Rear Speaker 6.5 3
2006 HONDA CIVIC 4DR SEDAN WITH STANDARD AUDIO SYSTEM
Location Size Depth
Front Speaker 6.5 3
Rear Speaker 6.5 3
yeah best upgrade is the heatunit only as a first step, when you pump more power into speakers it tends to really boost clarity
darktmt good result !! what I described is actually what I did to my car, yep I popped the CV spline out and thought Id whack the wheel back on and massage it back into place !! not very smart I burred it badly and had to get it fixed ! lol best bet is to get another jack n support the hub/brakes so it wont pop out.
http://img.tapatalk.com/d/14/05/15/ru3a9y5a.jpg
This my cockpit guys, was bored so took a pic
Heard from tyre king in my area that someone from melb came down and deposit on the fd2r front end and some interior parts
Got sad. Told him if the guy doesn't buy the armrest I'll buy it. Only thing missing in my car =|
Jprak nightly HJ visits
Anyway guys after the incident i return back to stock as i was too scared to put on the coil overs so im selling them.
if anyone in QLD want to buy BC coil overs FRONT ONLY contact me!
or if anyone in melb or sydney want to buy im driving down on the next month!
ILL SELL CHEAP!
Yeaaaah baby
@jprak got no money man.. :( gotta save up for my trip down to syd and melb haha
not sure how much to sell it for, probs sell for $300
For those in Victoria, come to the Garage Cafe opening tonight :)
https://www.facebook.com/events/831875176842006/
I'll be frequenting the Estblshd stand in an Adventure Time tshirt and beanie. Come say hi! :D
I have a Genuine Facia Kit. Perfect fit with a Alpine Doubledin headunit.
Front - 6.5" Soundstream rbc.6 80w rms - Powered by an 120w RMS Amp
Rears - 6" Alpine Type S - No Amp
Bass - Alpine 1000w RMS Type R Sub in a Alpine ported box to suit the sub.
Powered by an Alpine X-Power 1100w RMS Amp.
http://i194.photobucket.com/albums/z...26335320_n.jpg
Anyone know where i can source an oem front badge cheap? Haven't had much luck on ebay.
It fell of the other night :(
http://i.imgur.com/aC6e01w.jpg
I have a spare grille that comes with the badge if you want :)
$25?
I picked up onion rings from Chris :)
Honda_FD, were you Garage Cafe tonight? Did they announce your car being illegally parked? lol
What is your next mod guys. I'm thinking whether to get rear sway bar or auto power folding mirrors.
IOU, go with the sway bar imo, nothing more fun than taking corner without slowing down much ;)
Has anyone here registered for that Honda Network meet? Just sent mine in, trying to see else i should be expecting there :D
iou whats ya location ? I have a custom built 18mm RSB looking for a home (free B-) ) , Just needs new bushes and bracket ($50) if ya local ..........
I track my car so I ended up with Cusco F&R as they were a smidge stiffer.
Hey dude, is your axleback still for sale? $200 posted to melbourne as well or? Might be interested if i can get rid of my varex
hahaha only because youve asked five times in this thread. Still need to lower and put negative camber in the front since its on positive atm
http://i811.photobucket.com/albums/z...l/IMG_4210.jpg
http://i811.photobucket.com/albums/z...l/IMG_4203.jpg
hey guys
no more FD owner...just traded it in for a 1.5L i-vtec honda city
will be getting a modulo kit for it
