		I WAS GONNA SAY! I thought you sold it lol
		struggling to get b18c running....
 power going to starter motor but no crank whatsoever.
 does anyone know if you need to swap out the ignition lock cylinder with the key for the p72 ecu? wondering if it affects the immobiliser.
		what year model is the ECU?
		I suspect it's 1997 but I can't be sure.  OBD2A.
		OBD2a should have immobiliser, is it Australian spec ECU?
		Yes AU spec ECU. Will the stock EK1 ignition switch affect the ECU in any way?
 My starter motor could just  be dead.
		OBD2a Aus spec ECU would have immobiliser. Follow ECU-MAN's DIY article to disable the immobiliser
