Yeah I love rock'n the flutter!!
No BOV here :thumbsup:
woah luke!! 130wkw awsome stuff 13sec car easily there... just remember practise makes perfect when it comes to the 1/4. dont expect to run your best times strait up.
ur getting closer.
With rods i belive most if not all H-beam rods (eg EAGLE) require your block to be machined (notched) so the crankshaft can actually turn around. If not the H beams will not clear the internal block just under the water jacked. (lookup D16 SOHC block Notching for forged rods) You will see what i mean.
You would most likely need Ibeam (crower) or Xbeam (scat) to not require any block notching... This MAY mean you can do a bottom entry sump install.
Crower and Scat > Eagle. But much much more expensive.
Best just build your block properly man if your gonna open her up. Budget... vitiars pistons + eagle rods are very good value and some setups on turbod16 are even running close to 400whp
Yeah man
I've been look'n at
Bottom End Kit
http://fjdistributors.com/product_in...roducts_id=170
Forged Con Rods Need Notching of Block
http://fjdistributors.com/product_in...roducts_id=269
Rated to make about 450whp
Awesome Luke!!!
I'm with AAMI too but if that's the case I'll just change companies... as long as it's not expensive I don't care who I'm with.Why did U want to stay with AAMI?
d-series boost or b-series is the million dollar question.Driving me mad!
Ah I see.Those pistons etc in those 2 links are a great price as long as shipping isn't a killer.Buy em' both at the same time of coarse.Hopefully he will do a price.
