Originally Posted by
EUR003act
on the K24A3 TB, underneath the main inlet theres an extra flat piece of aluminium, even tho there is a rectangular cutout in the gasket, when pressed up against the RBB, this blocks the idle bypass... on the J32A3 however, youll notice there is no flat aluminium continuation under the inlet... so when using the normal gasket (or J32A3 gasket) on the RBB or RBC, the idle bypass will have a leak....
ill send him an email and check, im not sure if he has any '06 tsxs in atm... (he normally just deals with engines only)
