12.3m makes the car feel like it has a more sensitive steering, but it makes the car a nightmare to park...
so how does this make the CTR a more liveable car?
so the weight of 1345kg from Honda Australia is also correct?
6.6sec to 100km, not bad :p
Redbook specs ftw
http://www.redbookasiapacific.com/au...p?key=HOND07EE
Body Style HATCHBACK
Badge Type R
No. Doors 3
Seat Capacity 4
Series 8th Gen MY07
VIN Number SHHFN23607U ####
Drive Front Wheel Drive
Transmission 6sp Manual
Gear Location Floor
Steering Rack and Pinion
Engine Size 1998cc (2.0)
No. Cylinders 4
Engine Configuration In-line
Cam DOHC with VVT & Lift
Valves/Cylinder 4
Compression Ratio 11:1
Engine Cycle 4 Stroke
Engine Type Piston
Engine Location Front
Engine Number K20Z4 1#####1
Engine Code K2OZ4
Fuel Type Petrol - Unleaded ULP
RON Rating 95
Fuel Capacity 50L
Fuel Consumption Combined (ADR 81/01) 9.3L/100km
CO2 215g/km
Fuel Delivery Multi-Point Injected
Method of Delivery Electronic Sequential
Induction Aspirated
Power 148kW @ 7800rpm
Torque 193Nm @ 5600rpm
Acceleration 0-100Km/h 6.6 secs
Kerb Weight 1345kg
Tare Mass 1315kg
Wheel Base 2635mm
Length 4285mm
Width 1785mm
Height 1445mm
Track Front 1505mm
Track Rear 1530mm
Country of origin UNITED KINGDOM
Weight doesn't do justice, drive it and you will know how good the car is.
i think people need to actually test drive the car than commenting based on other peoples reviews. or what they read on specs..if you have driven the car and pushed it and gotten a feel you might have a different opinion...at the end of the day the type R is a new car for the market and if you have 44K laying around and want a honda civic type R then go for it. Those who complain about performance just go buy a s2000, 350Z, WRX, EVO, S15 or something with a V8 engine in it and you can have as much power as possible...just remember speed limits
The NEW CTR is looks KOOL!!
You sure it's not 11.2 and 11.8? There is usually a difference of at least .5 metre between wheel and body figures and body is usually the quoted figure.
11.2 and 11.8 is what this site lists
http://www.worldcarfans.com/print.cf...9.006/lang/eng
i got the info about the turning circle from carsales.com.au
going for a drive this saturday, will either confirm my doubts or prove me wrong...
