Thanks for the input, just a prototype for now so will consider adding more when i order in more.
Had a spare aus spec type R cluster lying around, was going to put it in but then my cars japspec (180) and IMO looks better at 180 max
So.. i decided to fuze both of them together lol
Automatic obd1 japspec non type r (pics off google)
http://i615.photobucket.com/albums/t...luster1085.jpg
Manual obd2 aus spec type r (pics off google)
http://img.photobucket.com/albums/v2...e/DSCN2078.jpg
Final product
https://fbcdn-sphotos-a-a.akamaihd.n...50d8b26bd0660e
Pretty much kept the japspec cluster but change the tacho, all the needles over and the carbon fibre backing
And just not use the plastic guard thing lol
Fixed some exhaust cracks http://img.tapatalk.com/d/14/08/01/ugu6yhyt.jpghttp://img.tapatalk.com/d/14/08/01/e7y2y5a9.jpg
lmao just use air compressor and blow
Anyways, cut my rocker cover today to expose the cam gears for the tune coming up.
http://i58.tinypic.com/t7lu35.jpg
Basically stripped it down, sprayed a silver base coat
http://i59.tinypic.com/141ts08.jpg
Slapped a thin layer of blue
http://i57.tinypic.com/2v3pijo.jpg
then i purposely lightly over spray with silver
http://i60.tinypic.com/2ah5lco.jpg
then a light coat blue
http://i60.tinypic.com/1zyygw8.jpg
then a thick layer of blue
http://i59.tinypic.com/2yp0is3.jpg
and smashed it with clear
http://i57.tinypic.com/dw3o5g.jpg
FINAL RESULT? also sprayed the spark plug cover the opposite (silver with light layer of blue then silver and clear)
http://i62.tinypic.com/ml5nbc.jpg
http://i57.tinypic.com/2yn2u0n.jpg
I will be sanding down the letters once its dryed and try to polish it up
Vinh, use a razor blade to cut the paint off the letters, and then wet sand with 400g on a metal block. Comes up a treat :)
I got these
http://img.tapatalk.com/d/14/08/08/5e6usa5u.jpg
Winning. What size?
Finally got rid of the shitty red calipers, and returned to stock colour, gold!
http://i930.photobucket.com/albums/a...ps579a6dd4.jpg
http://i930.photobucket.com/albums/a...ps3ebdd256.jpg
http://i930.photobucket.com/albums/a...ps6f82067b.jpg
Nice colour matched jack and stands. You're such a perfectionist..
